Cleaning chemicals?
0 Members and 1 Guest are viewing this topic. Read 1842 times.
Eric M.
Cleaning chemicals?
« on: 26 May 2015, 10:31 pm »
What sort of cleaning chemical do you prefer when tuning up your old gear?
-Pots?
-Gold RCA and speaker terminals?
-PC boards?
-Others?
Someone told me about Caig products but when I looked them up, there were about 20 different choices. So, I thought I'd ask you guys.
Eric M.
Hank
Re: Cleaning chemicals?
« Reply #1 on: 27 May 2015, 04:54 pm »
I've used Caig gold (small bottle with brush) for years for RCA plugs and jacks and other non-soldered electrical connections.  I can't remember at the moment what I used on pots last time a restored a vintage amp.
SteveFord
« Reply #2 on: 28 May 2015, 09:31 pm »
CRC Contact Cleaner works well for me.
It will flush the lubricant out so for that it would Caig DeOxit Gold
http://store.caig.com/s.nl/it.A/id.2172/.f
I got mine at Rat Shack a long time ago.
You could also just use WD40 for a little protector and lubricant.  I have a gallon jug of that stuff.
martyo
« Reply #3 on: 29 May 2015, 09:05 am »
I use Caig DeoxIT D5  per Frank Van Alstine.
Eric M.
« Reply #4 on: 29 May 2015, 04:22 pm »
What is the  Caig DeoxIT D5 recommended for?
Eric M.
Johnny2Bad
« Reply #5 on: 29 May 2015, 08:11 pm »
Not sure how often it would be encountered  or under which conditions it applies to, but technicians working on analog Tektronix gear (Oscilliscopes, etc) are warned not to use contact cleaners during repair or refurbishment. Apparently it is incompatible with Printed Circuit Board materials in the devices themselves and protective coatings on pots/controls. I would suspect "Tek"-quality manufacturing is rare on vintage audio gear but it might be worth a double-check if there is any doubt.
See:
http://www.vinylengine.com/turntable_forum/viewtopic.php?t=36702
... and Google provides other links (of course).
