BDA-1 and Spotify
0 Members and 1 Guest are viewing this topic. Read 1369 times.
stereoal
BDA-1 and Spotify
« on: 24 May 2015, 06:10 pm »
I have a Bryston BDA-1 connected to my Bryston stereo system and a subscription to Spotify.
1) Can I plug a laptop into the USB port of the DAC and listen to Spotify though the stereo?
2) Can I plug a smartphone into the USB port and listen to Spotify through the stereo?
How good/bad is the sound, given that this is Bryston's first-generation DAC?
Thanks for your replies.
ttsto
Re: BDA-1 and Spotify
« Reply #1 on: 24 May 2015, 06:38 pm »
If you have, why don't you try it?
Phil A
« Reply #2 on: 24 May 2015, 08:05 pm »
The USB is limited to 16/48 which should be fine.  I enjoyed listening to internet radio from the Squeezebox Touch and BDA-1 when I had them.
R. Daneel
« Reply #3 on: 28 May 2015, 07:49 am »
Hi!
The answers to your questions:
1. Yes
2. No
The USB is an older protocol but measured performance by Stereophile suggests it is very capable so the audio quality should be acceptable.
Cheers!
Antun
