Monitor Isolation Pads
0 Members and 1 Guest are viewing this topic. Read 4763 times.
ozoid
« on: 23 May 2015, 05:16 am »
While eagerly awaiting delivery of my Alnico monitors, I need to prepare to give them the best possible temporary home.
Here's the problem: they'll sit on a chest of drawers. Wooden boxes inside a wooden box. Resonance city. And the monitors will probably sit a little high, if so I'll want to angle them down slightly.
Google led me to this web site (http://ehomerecordingstudio.com/monitor-isolation-pad/) for home studios which provided a handy set of links to these isolation pads:
   Auralex MOPADS
   Auralex ProPADS
   Primacoustic RX7 Recoil Stabilizer
   Ultimate Support MS-80
   IsoAcoustics ISO-L8R
   Adam Hall SPADECO2
I've also come across references to ATS Acoustic Foam Monitor Isolation Pads and others have recommended, as an inexpensive alternative, foam or cork yoga pads.
http://www.amazon.com/Pack-inches-Black-Yoga-Blocks/dp/B002WCFXAG
http://www.amazon.com/Hugger-Mugger-Cork-Yoga-Block/dp/B000C9KZ18)
Anyone have any experience with any of these? Any others you recommend?
roscoe65
Re: Monitor Isolation Pads
« Reply #1 on: 23 May 2015, 10:40 am »
A factor may involve the form factor you need, but if a stand-type (as opposed to a pad-type) pad/stand works for you, I can wholeheartedly recommend the Isoacoustics stands.  I use them in a couple of applications and they work better than anything else I have tried.  They don't have a lot of different heights/sizes available, but they do offer some adjustabilty.  They include two different height cones to allow for either flat or angled setup.  If I had only one nit, it would be to offer different height tubes to make custom stands, but then that is what DIY is for.
I use them in two applications:  normal desktop for powered monitors at work (perfect out of the box), and as a component in a DIY speaker platform/stand (2" spikes - 3" maple platforms - Isoacoustics Oversized stand - MDF/metal medium mass stand).
« Reply #2 on: 23 May 2015, 01:02 pm »
Before purchse you would contact Herbie to see what he have in his line.
Herbie is the best in this field.
InfernoSTi
« Reply #3 on: 23 May 2015, 04:03 pm »
Ask Steve (Herbie's) about the big fat dots, as well as the grungebusters.  He has several other products he might recommend, as well.
ZLS
« Reply #4 on: 23 May 2015, 05:00 pm »
    Ozoid,
    You heard the Alnico Monitors on the IsoAcoustics Stands.
ozoid
« Reply #5 on: 25 May 2015, 03:56 am »
Thanks for the recommendation. You can tell that was a memorable listening session. Those stands could also give me a slight tilt downward.
Thanks again for the session. I'm open to playing hunches up to a point but I don't think I could have pulled the trigger on alnicos without hearing them. Just told a friend yesterday about that afternoon and he didn't know about FirstWatt.
sruffle
« Reply #6 on: 25 May 2015, 12:34 pm »
I will second the recommendation on Herbie's products for this.  Steve will guide you right and it is a good bang for the buck.
ssglx
« Reply #7 on: 25 May 2015, 01:59 pm »
I have great luck with #2 Vibrapods. Keeps all the energy of the performance intact (little loss to heat), maintains terrific clarity and gives the mid-bass a small and quite pleasurable boost.
I never could get any of the 'pods to work well (slowed bass) on my floorstanders, but they work wonders on my 25 lb monitors.
Chris
Audiophile58
« Reply #8 on: 13 Jun 2015, 10:19 am »
While in the U.K Blutac was brought to my attention it dissapates vibration very well ,and also
Adheres to the speaker and surface without damaging anything .to this day i allways put this about a dimes worth inside all 4 corners of the speakers . When you want to remove just hold  stand and tip towards the side it will break free. Never had any problems and speaker and is well anchored, for $10 one of the best tweaks in Audio !!
rar1
« Reply #9 on: 13 Jun 2015, 11:13 am »
Here is another approach.  I use the following for isolation of components and speakers:
You can see from my system view that my speakers are placed on top of the bookcases.  I have also had them placed on their sides inside of bookcases.
I have used the cork and rubber blocks for both monitors and floor standers.  For the floor standers, I purchase the 12 X 12 block sheets.
The rubber sheets work well under components, like turntables.  But these would work on top of a chest of drawers, as well.
My apartment house is on a bus route and alternate truck route, so there are always transmitted vibrations.  Both the blocks and rubber sheets work wonders in isolating the components.
Everything was purchased on eBay.
Rich
