jumpers for 1.7
0 Members and 1 Guest are viewing this topic. Read 3657 times.
Paddlefoot
jumpers for 1.7
« on: 21 May 2015, 10:43 am »
hi guys, what the best bang for the buck jumpers for the 1.7. thanks in advance for your input. Greg
rollo
  • Rollo Audio Consulting -
Re: jumpers for 1.7
« Reply #1 on: 21 May 2015, 02:16 pm »
  Stranded copper by any decent manf.  if you keep them short not much difference should be heard.  It would be prudent to use the same wire of the speaker cable used.
charles
NIGHTFALL1970
Re: jumpers for 1.7
« Reply #2 on: 24 Apr 2016, 03:24 pm »
I just replaced the metal jumpers on my 1.7s with a cardas audio jumper, and the speakers became clearer.  I am hearing things that I never noticed before.  I can hear tape hiss in the right channel of "stairway to heaven" that I did not notice before.  Now I am wondering if I should get Mye Stands for them?  Do they make a big improvement?
Paddlefoot
Re: jumpers for 1.7
« Reply #3 on: 7 May 2016, 09:34 am »
I`ll let you know in a few weeks if they do. i just bought one for my DWM woofer and on a short listen , it does sound better than the stock oval wooden plate that magnepan DWM ships with. i`ll play with it more today.
johnto
Re: jumpers for 1.7
« Reply #4 on: 29 Sep 2016, 01:56 am »
I just use heavy copper wire bent into shape on my 1.7 available for $.69 a foot at hardware store
Hiphile
Re: jumpers for 1.7
« Reply #5 on: 29 Sep 2016, 05:33 am »
In the next few weeks I'll  try three different types of jumpers in my new Magnepan .7  solid Cu jumpers- Anticables level 3, a combination of braid and solid core OCC Cu- Audio Sensibility, and a pair from the guy that built my speakers stands- no idea what they are but he swear for them.Will see what happens. Keep you posted
rhoneman1
Re: jumpers for 1.7
« Reply #6 on: 2 Oct 2016, 01:28 am »
I use Anticable Level 3 Reference Series Jumpers with my 1.6's
rhoneman1
Re: jumpers for 1.7
« Reply #7 on: 2 Oct 2016, 01:29 am »
On my 1.6's it was a day/night difference, fuller richer sound,
limniscate
Re: jumpers for 1.7
« Reply #8 on: 7 Oct 2016, 01:18 am »
I use Empirical Audio jumpers; they made a noticeable difference over the stock ones.
