0 Members and 1 Guest are viewing this topic. Read 22734 times.
It's a very simple concept -- better parts usually means better quality. A "high end" speaker implies higher quality crossover parts. Otherwise, what are you paying for -- a pretty cabinet?
Great discussion, guys. IMHO, if the parts used are within the indicated tolerances, even under stress tests (i.e. heat), then it should be good or quality enough. Then of course there are people who would like to go overboard, but it's also overkill and the money used for those could be implemented elsewhere in the design. Good engineering is about making the best possible design at a given amount or less. Although the "amount' is relative, you get my drift. Anyone with the means can throw a ton of money on a speaker project, in which any competent designer can make a decent or good sounding pair of speakers. But, the better engineers are the ones who can design or create something that can sound just as good, if not better, without suggesting on spending extra money on components that will not contribute much to the quality of the sound. Just my .02 cents. Cheers,Ian
Hi Guys,My speakers use stolen capacitors. Does that mean it won't sound good or could their be an improvement in SQ if I replace them with boutique capacitors.Cheers Rod
That's a false dichotomy, the whole design vs parts quality thing. I'm an engineer and I believe they are both important and an engineer who is limited to low quality parts is designing with one hand tied behind his back.
Thanks Rick,sometimes I think that different xover part might have an impact but not necessarily on the audio quality but just a different sound.Speaker are like good wine, sound prefer this and some prefer that.....The tempest is quiet good achievement. The only complaint I personally have I thing I've told and that is most likely my problem.
If you're wanting to change the sound adjusting the voicing will have far greater impact than switching out caps. It would be difficult for anyone to argue against that.
If the crossover design is all that matters, why not use the absolutely cheapest parts possible and save a few bucks? OTOH if those cheap parts do negatively affect the SQ, even a little bit, then this implies that quality parts do make a difference. Perhaps the expensive parts are not cost effective but many "audiophiles" are looking for that last little bit of performance, especially at the high end and don't mind paying a little extra to come closer to their goal.
What does a different voicing involves? Can you elaborate a bit, Rick? Is that what you suggested to me about a change in the xover for the mids?
Basically changing the output level of the drivers relative to each other. That was my suggestion to you.
Thanksdoes this require a new xover built, or would i be able to do it my own?As you may know, im interested in a 2 way kit, see if we can have something workout.
