XHADOW - XLR Connectors - The Best! -> SOLD
0 Members and 1 Guest are viewing this topic. Read 1667 times.
kenreau
« on: 11 May 2015, 06:01 pm »
Vampire "XHADOW" - XLR Cable Connectors - Silver plated Copper contact
Sleek, sexy, precision machine-art.  Considered by many to be the best audiophile caliber XLR connectors.  Set screw terminations allow solid and sonically preferred connections as well as experimenting with different cable recipes.  I ended up liking solid silver best.  Only made a change to the Devialet integrated which no longer required use of these XLRs.
The Xhadow Precision XLR is easily the finest XLR in the world, designed with respect for the audiophile perspective: Precision, purity, simplicity and elegance.
The main barrel and rear-nut are lathed from pure aluminum rod-stock and anodized in "Xhadow Gray" for a durable and non-conductive finish. This assembly houses an internal strain relief that is machined from brass.
Into this barrel assembly fits our Gender-Modules - either male or female plugs. Each one has an outer passive shell machined from brass and mirror plated, a machined Teflon dielectric, and pure copper machined contacts that have been silver-plated. Each contact allows the termination of wire to be completed via solder, set-screw, or both. This gives the end-user a tremendous amount of flexibility while also allowing them to guarantee a fantastic contact interface with their wires. Each Gender-Module is engraved with the "XHADOW" name along the top arc of the shell's front border, indicating top-orientation.
The fit of these connectors is smooth but very strong, with a tremendous amount of contact pressure to ensure perfect and consistent signal passage with a minimum of contact resistance. Priced per pair.
Finally ... an XLR that meets audiophile standards
This is a full stereo set of two males and two females.  Like new condition.  These sell for $160 per pair, or $320 for this set.  Asking $250 shipped to lower 48.  Paypal add 3%.
Thx
Kenreau
« Last Edit: 26 May 2015, 03:43 pm by kenreau »
kenreau
Re: XHADOW - XLR Connectors - The Best!
« Reply #1 on: 12 May 2015, 11:23 pm »
Bump and price reduction to $200.   :thumb:
Thanks for looking
Kenreau
kenreau
« Reply #2 on: 15 May 2015, 05:27 pm »
To sweeten the deal, I'll now include 2 feet lengths of the solid silver cable I used for my interconnect cable using all these parts.
The cable is a custom run commissioned by the Parts Connection and manufactured by DH Labs.
BL-Ag "balanced" interconnect cable, 2 x 23 awg w/shield and drain wire (od: 6mm), (pure 99.99% solid-core silver, foamed teflon, tape-wrap dielectric). NOTE: Custom made for pcX(ConneX) by DH Labs
The cable configuration is suitable for use in either a balanced xlr cable, or conventional single ended.  Right now it is on special for 50% off at the pcX and would sell for approx $55.
You get the best XLR connectors and best solid silver balanced cable for $200.  What a bargain  :thumb:
Thanks for looking
Kenreau
kenreau
Re: XHADOW - XLR Connectors - The Best! plus Solid Silver cable
« Reply #3 on: 20 May 2015, 03:35 pm »
Bump to the top.  Make a reasonable offer if interested.
Thanks for looking
Kenreau
kenreau
SOLD to brian / brj
Ken
