JDS Labs - CMOYBB Altoids headphone amp + FiiO L9 LOD cable > SOLD
0 Members and 1 Guest are viewing this topic. Read 744 times.
kenreau
JDS Labs headphone amp and bass booster, all built into a discrete Altoids tin. Runs on a single 9V battery, or optional power supply (not included)
FEATURES OF THE CMOYBB V2.03
cMoyBB is the most fully featured cMoy made.
Bass Boost
JDS Labs's success is due to cMoyBB's legendary bass boost switch. Switched off, your original audio signal is amplified. Switched on, bass increases up to 9.4 dB for a perceived 2x increase in bass volume.
Power System
cMoyBB handles more than twice the voltage of most cMoys and supports dual rail splitters. The result is over 200% higher power handling than the original cMoy! Decoupling capacitors on all power pins significantly enhance opamp stability and sound quality.
Power Input Jack
cMoyBB's power input jack allows you to power the amp from your desk. Optional charging support also provides convenient, integrated 9V NiMH battery charging.  Optional power supply not included in this sale.
Enclosure
cMoyBB is cased inside of a brand new Altoids ® Peppermint tin, protecting the circuit from some forms of external EMI / RF interference.
TECH SPECIFICATIONS
Frequency Response (20Hz-20kHz)   +/- 0.1 dB
THD+N (20-20kHz, 150Ω)   0.002%
Channel Balance (at 50% volume)   +/- 0.6dB
Output Impedance   0.6 ohms
Run Time   8-50 hours
Volume Potentiometer Taper   3B
DIMENSIONS
Case Dimensions   116 x 64 x 21 mm
Weight   3.6 oz
ALSO includes the accessory FiiO L9 LOD cable
The FiiO L9 LOD cable directly connects your headphone amplifier to the line level outputs of an iPod or iPhone 30-pin dock connector. Its HPC-22W cable consists of 173 total strands of PCOCC-A copper for virtually lossless transmission, hi-speed response, and natural clarity.
I would strap these units on to my iphone or ipod nano and enjoy greatly enhanced sound quality in the gym, hiking or on the ski slopes.
Package deal for $50 including usps shipping to lower 48.
http://www.jdslabs.com/store#featured
« Last Edit: 16 May 2015, 01:42 am by kenreau »
kenreau
SOLD.
Kenreau
