0 Members and 1 Guest are viewing this topic. Read 741 times.
Material and Engineering Summary:Universal fit for all turntables, General Use for basic TurntablesMachined from billet 6061 aircraft grade aluminumDimensions: 3.45 inch diameter by 1.55 inches heightWeight: (1LB/454 Grams)Minimum spindle height 1/8Engineered to PerformTTWeight is designed to provide improved coupling and center dampening at a budget price, translating to better sound at the stylus. The Weight will add a more tightened Bass response with more pronounced mid range and highs. Machined from Solid billet Aircraft Aluminum, 32 Micro Inch Surface Finish.Benefits· Universal Fit, cleaner sound, improved dynamics and frequency response· Lower Distortion Levels· Bored Center holes 32 Micro Inch Surface Finish will not damage spindle· Clears Spindles 1.0 depth· TTWeights can be mounted while turntable is turning· The Spindle bore is not drilled, it is CNC bored to +/-.001 diameter tolerance and is concentric to the outside diameter by .0005 or less.· The bottom has a concave Radius, .015 deep with a .250 or .375 on the clamps systems on the outside perimeter for correct seating on the LP perimeter. This increases the contact pressure vs. small diameter weights. The top has a beautiful arc that is a very attractive finely machined surface.
