0 Members and 2 Guests are viewing this topic. Read 21560 times.
It's not about audible RF, it's about how the RFI interference affects (effects?) a circuit...
Speed, the verb 'affect' means 'influences'; the verb 'effect' means cause.
Ok, if we're giving grammar lessons, 'effect' is generally a noun not a verb. No offense intended, these have got to be two of the most commonly confused words in the English language.
The thing here is the interference affects the circuit, but to the listener it may be somewhat like a sound effect.
come on guys,the only way hum can get into a circuit is through a low level signal high gain circuit,these use regulated power supplies with very low hum ripple and seilded cables at the input(s) of the gain stages,there is no need to seild the power cable,just the signal cable of the gain stage usually the first one.
George - While the shielding thickness practically implemented on either ICs or power cords is quite effective against capacitivly coupled RFI noise, isn't it too thin to be effective against inductively coupled mains hum?Skin depth vs Frequency
