noise from speaker
0 Members and 1 Guest are viewing this topic. Read 1081 times.
jhrlrd
noise from speaker
« on: 9 May 2015, 09:52 pm »
Hi all, I was running a cheap $130 DVD player as a source until I got my ASi/Modwright/OPPO105 back from mod, and it idled silent.
Once I got the front end back, it now emits a hiss/buzz from the speakers.
at half volume, I can hear the hiss from the listening position.
The player runs into a jadis DPL pre, then on to a first watt F6.
The first thing I tried was lifting the ground to each of the power supplies and oppo, one at a time, to no avail.
I moved the ground wire that feeds the MW board  to come off the ground rails,
and it helps, but not completely.
« Last Edit: 12 May 2015, 05:16 am by jhrlrd »
jhrlrd
Re: noise from speaker
« Reply #1 on: 12 Jun 2015, 06:57 pm »
So upon recommendation from the modifier, I moved a ground wire from one postition
directly to the negative rail that feeds the rca output negative. That solved it.
Then i hooked a wire from the ground post on the chassis of the preamp to the center screw on the wall receptacle, and floated the ground
on the preamp's power cord. This eliminated a very faint 60hz buzz. What remains is a low pitch hiss, not audible from the listening position.
 could be tube rush, even though I'm using vintage low noise medical 12Au7's
Blu99Zoomer
« Reply #2 on: 27 Jun 2015, 02:25 pm »
Hey jhrlrd,
Did you solve your hiss/buzz issue completely?
Blu99Zoomer
