BR-2 remote control illumination
0 Members and 1 Guest are viewing this topic. Read 2786 times.
R. Daneel
« on: 4 May 2015, 09:16 am »
Hi!
Can someone tell me what is the colour of illumination on the BR-2 remote control? Does Bryston offer different colours like they do with LEDs on the dress panels of their equipment?
Also, I read the BR-2 user manual but there is something I don't understand. With the BDP-1, does it allow for searching within a track like with a CD player?
Antun
R. Daneel
Re: BR-2 remote control illumination
« Reply #1 on: 4 May 2015, 03:24 pm »
Anyone please?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 4 May 2015, 03:52 pm »
White only.
james
R. Daneel
« Reply #3 on: 5 May 2015, 10:19 am »
White only.
james
Okay! Thanks James!
What about the track search function like on a CD player? Is it supported by the BR-2?
From what I can see in the BR-2 manual, you can skip tracks by using the buttons NEXT and PREVIOUS. What do the buttons FORWARD and BACK do? The symbols "<<" and ">>" certainly suggest these are used to search for a specific part within a track.
Any thoughts?
Cheers!
Antun
« Reply #4 on: 5 May 2015, 11:33 am »
Okay! Thanks James!
Any thoughts?
Cheers!
Antun
Hi
The next and previous will allow you to go to the next track or previous track on your play list.
james
R. Daneel
« Reply #5 on: 5 May 2015, 03:01 pm »
Hi
james
Hi James!
How about the FORWARD and BACK buttons? What do they do?
Cheers!
Antun
« Reply #6 on: 5 May 2015, 03:46 pm »
Hi James!
Cheers!
Antun
Hi
They will not control the BDP
james
R. Daneel
« Reply #7 on: 5 May 2015, 03:53 pm »
Hi
james
Thank you James!
Then it might be a good idea to correct the picture in the BR-2 manual.
Cheers!
Antun
Gibalok
  • Metrum Pavane/Manley Shrimp/4BSST2/Penaudio Cenya
« Reply #8 on: 19 Oct 2015, 06:39 pm »
Is it possible to select inputs on BP26 using BR2?
Marius
« Reply #9 on: 21 Oct 2015, 09:42 am »
HI Antun!
i take it you're referring to the last page of http://bryston.com/PDF/Manuals/300020[BR2].pdf?
At least the BCD should be added.... I use it on a daily basis  :thumb:  especially the 'secret' 0, to turn off the lights, is one of my favorites.
Marius
Thank you James!
Cheers!
Antun
Wim J
« Reply #10 on: 22 Oct 2015, 01:39 pm »
White only.
james
hu? White??? :scratch:
 My BR2 has blue background lighting. I did not do any mod's on it,...  :nono:
