SOLD: Eastern Electric MiniMax BBA
0 Members and 1 Guest are viewing this topic. Read 1804 times.
Hear Clifford Brown
« on: 1 May 2015, 04:03 am »
SOLD Eastern Electric MiniMax BBA.  It is a tube buffer with both a variable gain control and a volume control.  It has one set of input/output jacks.  If you only have one source, think of it as a tube preamp with variable gain.  But it has been described in reviews as much more than that in terms of how it can be used and how it can improve the sound of a wide range of audio systems through the use of adjustable gain.
It uses three tubes: two 6BM8/ECL82 in the buffering circuit, and one 6X4/EZ90/U707 rectifier.  Included are the original tubes plus the following recommended and purchased from Bill at Morningstar Audio, the importer for Eastern Electric: a pair of Thorn from Japan NOS 6BM8’s and two different rectifiers, a Tungsol 6X4W rectifier and a Haltron CV493/ 6X4 Black glass rectifier.  I paid $94 for these 3 months ago.  I will cover PayPal fees but shipping at actual cost is buyer’s responsibility.
$450 from 98424
Specifications:
Maximum input: 6V
Gain (1KHz): 0dB to +18dB
Input Impedance: 220K ohm
Output Impedance: 800 ohms ¡V 10K ohms
Signal to Noise: 95dB to 85dB
THD: 0.1%
Frequency response: 10Hz - 100KHz
Power consumption: 35VA
Measurement: 165 x 127 x 292mm
Links:
http://dagogo.com/eastern-electric-minimax-bba-preamplifier-review
http://www.eeaudio.com/eeaudio_009.htm
« Last Edit: 13 May 2015, 03:08 am by Hear Clifford Brown »
Hear Clifford Brown
Re: FS: Eastern Electric MiniMax BBA
« Reply #1 on: 12 May 2015, 06:53 am »
bump for lower price, was $500 now $425
