Silk Monitors in highly figured sapele - SOLD
0 Members and 1 Guest are viewing this topic. Read 3940 times.
jsalk
    • Salk Signature Sound
« on: 30 Apr 2015, 04:07 pm »
This is a pair of Silk Monitors done in sapele with black front baffles and matching speaker stands.  We looked through our inventory and found some very highly figured sapele.  We used a gloss finish to make sure the sapele really popped.
Here are some pictures...
And a close-up...
The stands were designed to allow the speaker wire to be fed up through the center column from the bottom.
The Silks are priced at $3495 and the matching stands are $400.
These are available for immediate delivery.
- Jim
« Last Edit: 4 May 2015, 05:59 pm by jsalk »
Austin08
Re: Silk Monitors in highly figured sapele
« Reply #1 on: 30 Apr 2015, 04:23 pm »
Message send.
HT cOz
« Reply #2 on: 1 May 2015, 12:17 am »
Wow very cool. Reminds me of some speakers I built once.  Naturally yours are way more professional.
Q3Di
« Reply #3 on: 4 May 2015, 04:19 pm »
What is the nominal impedance?
What is the recommended power to drive these in a medium size room? Ayre AX7 integrated with 60W into 8 ohm is adequate?
jsalk
« Reply #4 on: 4 May 2015, 05:59 pm »
These are 8 ohm speakers.  As for power, the AX7 would probably work in a medium sized room at moderately high volume levels or less.  They are about 84db sensitive as I recall, so more power would probably be beneficial.
I should note that they were just sold.
- Jim
