Amp / speaker stands
0 Members and 1 Guest are viewing this topic. Read 716 times.
Markwatkiss
« on: 29 Apr 2015, 10:17 am »
For your consideration a pair of granite speaker stands measuring 1 foot square and 1/4" thick.Each stand rests on a quad of black audio points which are mounted at each corner on the underside of the stand.The footers are seamlessly mated to the underside corners of each stand by a removable screw.Finished in anthracite black with subtle white flecks the stands are ideal for speakers or mono block amps with a small footprint.
Offered at $55 shipping included from 49783.The audio points alone are worth double that price.
I seem to be encountering some difficulty uploading pics so if you are interested simply send a pm and I will flip you some.
Goosepond
  • Virna!
Re: Amp / speaker stands
« Reply #1 on: 29 Apr 2015, 03:25 pm »
PM sent.
Gene
