A new BP-6 preamplifier
0 Members and 1 Guest are viewing this topic. Read 2573 times.
R. Daneel
« on: 26 Apr 2015, 04:02 pm »
Hi folks!
Does Bryston plan on upgrading the BP-6 model this or next year?
I quite like the BP-17 but I must say I prefer the traditional mechanical control of the BP-6 as remote operation is very low on my list of priorities. Of course, the BP-17 is Bryston's most recent design so most likely it is supior in audio quality but I was wondering if there is going to be a BP-7 with less inputs and mechanical switches?
Any thoughts?
Cheers!
Antun
  • The Demo is Everything!
    • http://www.bryston.com
Re: A new BP-6 preamplifier
« Reply #1 on: 26 Apr 2015, 04:11 pm »
Hi folks!
Any thoughts?
Cheers!
Antun
Hi Antun
No changes planned for the BP6.
james
R. Daneel
« Reply #2 on: 26 Apr 2015, 09:08 pm »
Hi Antun
james
Hi James!
Are there significant differences between BP6 and BP17 in terms of audio quality? The BP17 is only slighly more expensive but like I said, I prefer mechanical controls rather than sensor-type.
Cheers!
Antun
« Reply #3 on: 26 Apr 2015, 09:16 pm »
Hi James!
Cheers!
Antun
They are very close in terms of the analog circuity - the BP17 uses more surface mount circuit boards whereas the BP6 is hole through circuit boards.
james
R. Daneel
« Reply #4 on: 28 Apr 2015, 05:23 pm »
james
Hi James!
That is intriguing! Can you please answer these questions for me?
1. what are the current retail prices for the BP-6 and BP-17?
2. how much does the preamplifier section of the B-135 differ from the BP-17? Apart from the obvious difference that B-135 has no balanced output and that it has less inputs than the BP-17, are there differences in electronics design that would make the BP-17 a better sounding preamplifier?
Cheers!
Antun
Cheers!
Antun
« Reply #5 on: 28 Apr 2015, 05:45 pm »
Hi James!
Cheers!
Antun
Cheers!
Antun
Hi,
The retails vary depending on the country.
The B135 preamp section is identical to the BP-17.  The B135 does not have Balanced out because it is an integrated amp - same number of inputs though as far as I know.  No difference in the preamp sections so no advanatge there.
james
R. Daneel
« Reply #6 on: 29 Apr 2015, 05:41 am »
Hi,
james
Thanks James!
Okay, one final question:
does that mean a B-135 is essentially a BP-17 preamp and 2.5B power amp in one chassis?
Cheers!
Antun
« Reply #7 on: 29 Apr 2015, 06:50 am »
Thanks James!
Cheers!
Antun
Correct - that way the Integrated is not a compromise over separates.
james
R. Daneel
« Reply #8 on: 29 Apr 2015, 07:34 am »
james
That is fabulous! Thanks James!  :thumb:
Right, well then, that moves the B-135 on the top of my list of contenders.
Cheers!
Antun
