Canary CA-306 power amp
0 Members and 1 Guest are viewing this topic. Read 935 times.
Markwatkiss
« on: 24 Apr 2015, 04:46 pm »
For your consideration a new Canary CA-306 power amp.Canary Audio is an established US manufacturer based in California.Their products are handcrafted and designed for the audiophile.
The CA-306 is a push pull triode configuration with 300B output tubes,Hovland music caps,custom hand wound transformers,and independent choke filtered voltage supplies for each channel.
Rated at 24 wpc it has the finesse of a SET amp with enough punch to drive most speakers.
As stated this is a new unit and has only been removed from the factory box for photos.
Offered at $2295 which is 60% off retail and includes a full tube complement,which is not provided by Canary.
Shipping will be within 24 hours post payment.I will accept:bank wire,certified bank draft,personal check,US Post MO and I would invite you to check my audiogon references under my user name.
