Help learning to build by own crossovers............
0 Members and 1 Guest are viewing this topic. Read 2015 times.
RH Customs
I need help on building crossovers of my own. I am making a system that will consist of a Dayton 1 1/8 silk dome 5 1/4 for a mid and a 8 for the woofer and will be using a split cab design.
The enclosure will be
41.5 inches tall
10 inches wide
12 inches deep
The bass cab will be 27X8.5X10.5
look at the link for a general idea of what I would like to do.
Please help.
http://www.audiocircle.com/index.php?action=gallery;area=browse;user=3750
clm811
  • Just listen.
Re: Help learning to build by own crossovers............
« Reply #1 on: 11 Feb 2024, 01:56 pm »
Hi
I'm Chuck from SF, California.
I've been building crossovers for many years.
In this new age of DSP and inexpensive bClass-D amplifiers, I have found the best results with active crossovers and multi-amping.
Other than pro-gear, an inexpensive  many manychoice I've found is the XKitz (not affiliated)3-way LR 24db/octave crossover kits and also available premade. They use plug-in frequency modules for simple choice of crossover points.
For amps, Ive had good luck with Ice Power and  Sure amps.
For passive crossover design I recommend reading a lot and LDC by Dickson is a good starting point.
Ciao
S Clark
« Reply #2 on: 11 Feb 2024, 03:12 pm »
Passive crossover design is doable IF you have a good measurement device.  Otherwise, you're best off hiring it done.
And a three way is 10x more difficult than a two way.
« Reply #3 on: 11 Feb 2024, 03:35 pm »
This topic are from 2004, RH Customs may have solved the problem.
[email protected]
« Reply #4 on: 20 Feb 2024, 11:35 am »
41.5 inches tall
10 inches wide
12 inches deep
Please help.
I will be watching this topic.
