(1) 2.5mm x 5.5mm Male to (2) 2.5mm x 5.5mm Female
0 Members and 1 Guest are viewing this topic. Read 983 times.
jtwrace
    • TIPP YouTube Channel
The tittle says it all.  I'd like a small molded part but would take something like this.  I've looked high and low but can't find them.  They must be the size above.  I'm just trying to avoid making one as I'd think it has to be around.
HAL
Re: (1) 2.5mm x 5.5mm Male to (2) 2.5mm x 5.5mm Female
« Reply #1 on: 19 Apr 2015, 12:29 pm »
Cannot find any size details, but this is close:
http://www.amazon.com/Magicshine-Mj-6018-Y-cable-Splitter-Headlamp/dp/B00S2R8LJ0/ref=sr_1_75?s=electronics&ie=UTF8&qid=1429446453&sr=1-75&keywords=power+y+splitter+cable
If that does not work, I can make you one using a plastic box for the two jacks and a cable for the plug end.
