Why not flush mount the drivers?
0 Members and 1 Guest are viewing this topic. Read 1590 times.
zybar
« on: 29 Sep 2004, 12:29 am »
Brian,
I know that the 40's produce excellent sound without flush mounting the drivers, I was just curious about why you don't flush mount them?
If I tried to flush mount the drivers, would that be impacting the sound (in either a positive or negative fashion)?
George
JoshK
« Reply #1 on: 29 Sep 2004, 12:30 am »
Are your's sunk deep?  My are pretty flush with the face.
shokunin
« Reply #2 on: 29 Sep 2004, 12:51 am »
I think it's one of those damn if you do, damn if you don't.  I think Marbles is on the right track, use some 1/8-3/16" weatherstripping foam/rubber from HD/Lowes to raise the neo's a bit to make it more flush.
mac
Re: Why not flush mount the drivers?
« Reply #3 on: 29 Sep 2004, 02:10 am »
Quote from: zybar
You would absolutely be able to see the effects of not flush mounting the drivers if you took a MLS measurement of your speakers.  Whether or not you'd hear its effects is another story.  FWIW, these types of diffraction effects cannot be engineered out through the crossover.
Marbles
« Reply #4 on: 29 Sep 2004, 02:21 am »
FWIW, my RM30 has perfectly flush mounted midranges, my 626R's are slightly recessed, like my RM40's were.
Brian Cheney
    • http://www.vmpsaudio.com
offset
« Reply #5 on: 29 Sep 2004, 02:32 am »
Either a rectantular trim ring over the panels, or an MDF gasket under the panels will solve the problem.
3/16" offset is not a sonic factor, given the range of movement of people's heads while listening.
