Questions regarding materials on Bryston equipment
0 Members and 1 Guest are viewing this topic. Read 1139 times.
R. Daneel
« on: 18 Apr 2015, 04:38 pm »
Hi!
I was wondering, does Bryston use aluminium or steel to make external casing of these products:
- BHA-1
- BDP-1
- BDA-2
Also, would it be possible to tell me if BHA-1 uses some OP-AMP ICs or is it everything made froe with discrete components?
Cheers and thanks!
Antun
gdayton
Re: Questions regarding materials on Bryston equipment
« Reply #1 on: 20 Apr 2015, 10:34 pm »
The chassis on those components are steel with aluminum dress panels. The BHA1 uses fully discrete operational amplifiers. No ICs in the analog audio path.
SFOX
« Reply #2 on: 21 Apr 2015, 12:19 am »
Are the chassis for the 3B SST2 and 4B SST2 aluminum or steel with aluminum dress panels ?
Do you sell more 17 inch or 19 inch with handles ?
R. Daneel
« Reply #3 on: 21 Apr 2015, 12:00 pm »
Thanks Gary!
