Perhaps a Dumb Question - Solid State Relay for 12V Trigger
0 Members and 1 Guest are viewing this topic. Read 766 times.
krikor
  • Initiative comes to those who wait.
    • AudioSnoop.com
So i've got a solid state relay I plan to use for a homemade 12v trigger (control voltage is 9-16 VDC). The output is rated up to 1.5A/240V and no other parameter is given. I assume (perhaps incorrectly) that this would simply translate to 3A at 120V... correcto?
I'm planning to use this on an amp rated at 130w max power draw which would equate to only about 1A/120V. Are there any "hidden" factors I need to be concerned about?
Just want to make sure  :green:
