Extremis?
0 Members and 1 Guest are viewing this topic. Read 1801 times.
JohnR
Extremis?
« on: 28 Sep 2004, 09:35 am »
Hi Kevin, will you be carrying the new Adire Extremis 6 driver?
And, have you heard it? ;-)
Kevin P
    • http://www.diycable.com
Extremis?
« Reply #1 on: 28 Sep 2004, 02:54 pm »
John R:
There is a very good chance I'll be offering kits based on both the new 6" & the 4" driver at Creative Sound.    Bob and I are showing a line array with the new 4"s at RMAF next week.
Right now I don't have any details because all I have in hand is the prototype 8 Ohm & 16 Ohm drivers.   Once I have a production unit then I'll start the design process to offer a few kits using the Parts Express finished cabinets.
As for a timeline.... I don't have any.   It will largely depend upon my cash flow and available time.
JohnR
Extremis?
« Reply #2 on: 6 Oct 2004, 01:52 pm »
Hi Kevin! I guess I was just wondering if you're in on the pre-order or if that has to go direct thru Adire
J
Kevin P
Extremis?
« Reply #3 on: 6 Oct 2004, 09:42 pm »
John R:
You would need to talk to Adire for the pre-order.    They have them priced attractively to get the ball rolling.
I have both the 8 Ohm & 16 Ohm prototypes here on the shelf but I havn't done anything with them other than measure the T/S parameters.
