Bryston amps | Converting a 220V to a 120V
0 Members and 1 Guest are viewing this topic. Read 1715 times.
AJAudio
  • The sweet sound of music...
« on: 11 Apr 2015, 09:16 pm »
Hi,
Can a xB-SST2 amp that is labelled as a 220v model be converted to a 120v model ?  (For used in Canada)
Looking at the schematic there seems to be a few jumpers about voltage selection.
Can this conversion be done by the end user or must the amp be returned to Bryston for the conversion ?
If so, can you provide an estimate of the cost ?
Thank you!
Grit
  • - Garrett
Re: Bryston amps | Converting a 220V to a 120V
« Reply #1 on: 11 Apr 2015, 09:30 pm »
I think they can do it, but I'm certain it has to go back to Bryston.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 12 Apr 2015, 11:30 am »
Hi,
Thank you!
Hi AJ
Never by the end user - too many safety concerns. :nono:
james
