0 Members and 1 Guest are viewing this topic. Read 4876 times.
I'm not sure I'd call REW a standard, it is popular though because it has a lot of analysis tools, is cross platform, and has constant support from the author (JohnM) on the REW forum. And it's free.With that said... your measurement looks to me like it might be from the laptop mic.
There are settings in preferences in REW for response bandwidth. Check those to see if is setup correctly. You should also check the calibration file is loaded.
I like the blue chart. Starting to look better. YOu have those multiples of 50 hz and 100 hz hitting you. Must be hitting room dimensions in multiples of 5.6 feet (200 hz). What are your room dimensions?
When I look at your 'dips" they are between 50 and 60 hz and all multiples of that. So that is between 5 and 6 feet which lines up as multiples of both the depth and width. What that says to me in my experience is you cannot defeat it. It is what it is and the possible solution is offset the speakers side to side and front to back slightly.
RPG or QRD type diffusion panels would help with the comb-filter problem and are much more desirable than turning your room into an anechoic chamber. See link http://arqen.com/sound-diffusers/Scotty
