for the new amps: Nuprime, please include subwoofer out
0 Members and 1 Guest are viewing this topic. Read 2533 times.
Silvian
Dear Nuprime,
I hope many will be in agreement with me in asking you to include a subwoofer out in your future, especially budget (<$1k) amplifiers.
I can see why some, including you, may consider the amp in the subs as being of a lower quality than what you provide, but being on a limited budget I think it is better to have a decent active sub rather than no sub. For the last 15 years I considered a pair of bookshelves and a sub a far better option (my value for money) than a true full range pair of speakers.
I am in the lucky situation to have an excellent sub with speaker level input but 1. it's getting old and 2. not many makers still offer this input. External crossovers are rare and I suspect they'll never be a 'thing' one could reliably find on the market.
Thank you
rustydoglim
    • www.nuprimeaudio.com
Re: for the new amps: Nuprime, please include subwoofer out
« Reply #1 on: 7 Apr 2015, 04:31 pm »
You will be glad to know that not only IDA-16 has RCA line out, the soon to be shipping (in May) IDA-8 ($899) also have line out.
Oops, I just leak the news about IDA-8.  Please be patient, more info will be available in two weeks.
IDA-8 is yet another new Class-D design specifically for speakers in the $3000 and below (it is good enough to match high efficiency high end speaker).
Inputs:
1 x USB PCM / DSD Digital (PCM UP TO 384K & DSD UP TO DSD256 )
1 x Coaxial Digital S/PDIF (PCM UP TO 192K)
1 x Optical Digital S/PDIF (PCM UP TO 192K)
1 x BTR / WiFi  INPUT
1 x Analog Stereo RCA
Outputs:
1 x Optical (up to 24 bit/192 kHz)
1 x Stereo RCA (Line out)
1 x Stereo Speaker (Binding Posts) Output
USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz,and DSD 2.8MHz, 5.6MHz, 11.2MHz
S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz
Maximum Sampling Rate: 24-bits / 32-bits
Bit Resolution: 16-24-32 bits
Power output: 140W x 2 (4-Ohm)
THD+N: 0.004%
Peak Output Power: 280W
Frequency Response: 10Hz to 80kHz
