0 Members and 1 Guest are viewing this topic. Read 2836 times.
So I can use my 6ohm speakers (4ohm min.) with a 6-8 ohm receiver and be ok? If I'm using an 8ohm amp, do I risk damage to the amp or the speakers? Or something else?I didn't really explain the binding posts very well. Here's a clip from the manual on my Yamaha DSP-A780.You can see the bare wire going into the hole in the collar I was trying to describe. ...
What can I do about the vibrations my equipment will be experiencing in the builtin shelves? I'm assuming there's some way to help isolate them - what would this concept be called so I can look into it more?
