***SOLD*** GR Research O-3 Omnidirectional Speakers
0 Members and 1 Guest are viewing this topic. Read 1651 times.
Early B.
***SOLD***
For sale is a pair of GR Research O-3 speakers in very good condition. They were professionally built using solid joined black walnut baffles and bases. The sides and rear of the cabinet are textured black. They are beautiful speakers and very wife friendly.
The O-3 was designed to create an omnidirectional sound field. They sound huge for their size. Imaging is superb and much better than one would expect. These speakers were built with Erse XQ inductors and Sonicaps and Erse Pulse X poly caps in the woofer circuit. No Rez lines the interior.  The crossover was modified with a Sonicap Platinum bypass cap in the treble, and a Jupiter Beeswax bypass cap in the mids. The internal wiring was also upgraded. These have the XBL-2 rear drivers.
The O-3 works best well out into a room and away from boundaries. Imaging is pin point and vocals appear to be standing in front of you. All of the instruments are seemingly well placed and the music fills the room. These things play live music in a way that makes it feel live. They are fast, clean, sound powerful, and quite enjoyable to listen to. They really make standard types of speakers sound two dimensional. I also used them for home theater and they sound phenomenal!
O-3 Specifications:
•   3-way bass reflex design
•   Simple parallel network
•   BG Neo3pdr tweeter
•   5.25 inch composite paper woofer with phase plug type dust cap, polymer chassis, and vented Kapton voice coil
•   Frequency response is better than +/-2dB at 20 degrees off axis.
•   -3dB is 50Hz
•   Sensitivity is 86 dB (1watt/1m)
•   Recommended amplification is 8-100 watts RMS
•   Impedance 6 ohms nominal with a 4.5 ohm minimal dip
•   Dimensions: 39" H x 7" W x 13.5" D
« Last Edit: 7 Apr 2015, 09:19 pm by Early B. »
SlyFuu
Re: FS: GR Research O-3 Omnidirectional Speakers
« Reply #1 on: 7 Apr 2015, 02:55 pm »
These are stunning!! Why are all the good deals always out of state... GLWS!
