Denon POA-1500
0 Members and 1 Guest are viewing this topic. Read 5026 times.
bladesmith
  • water quenching steel since 2001....
    • palmer knives
Denon POA-1500
« on: 5 Apr 2015, 06:24 pm »
I am selling my Denon POA 1500.
Pros: It is as pictured,  in very god condition and has been gone through and tested, (all) light bulbs have been replaced and this unit is a beauty. Works perfectly.  Sounds perfect. A classic.  And is dead quite. The inside looks brand new.
Cons: the rear speaker terminals are weak and have some cracking. They work fine, but are loose. I haven't the time to fix or replace. They all work fine, as intended,  but the terminals will probably needed replacement at some point.
If you have any questions,  please msg me.
I am asking $400.00 plus shipping,  which will probably be around $47.00. (Unless you pick it up locally. )
Thank you,
V. ...
Specifications
Power output: 150 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.002%
Input sensitivity: 1V
Signal to noise ratio: 123dB
Speaker load impedance: 4Ω to 16Ω
Dimensions: 470 x 168 x 418mm
Weight: 20kg
« Last Edit: 2 May 2015, 01:42 pm by bladesmith »
bladesmith
    • palmer knives
Re: Denon POA-1500 $400.00
« Reply #1 on: 15 Apr 2015, 10:45 pm »
Bump......
bladesmith
    • palmer knives
« Reply #2 on: 18 Apr 2015, 05:08 pm »
Price drop to $350.00 plus shipping ($47.00)
The original Rose wood veneered side panels are in very good shape and original. If anyone wants other pics, please PM me.
Thank you,
V..
bladesmith
    • palmer knives
Re: Denon POA-1500
« Reply #3 on: 20 Apr 2015, 03:48 am »
Bump with price drop..
$325.00 + shipping
bladesmith
    • palmer knives
Re: Denon POA-1500
« Reply #4 on: 2 May 2015, 01:42 pm »
Bump with another price reduction.... :thumb:
$300.00 + shipping ($47.00)
Thanks....
bladesmith
    • palmer knives
Re: Denon POA-1500
« Reply #5 on: 10 May 2015, 07:08 pm »
I think I will keep this and find new terminals.
Thanks for looking. ....
V.......
« Last Edit: 13 May 2015, 03:07 am by bladesmith »
grandwazoo
Re: Denon POA-1500
« Reply #6 on: 21 Jun 2015, 12:41 am »
Hi
Is it still available....Thanks
bladesmith
    • palmer knives
Re: Denon POA-1500
« Reply #7 on: 21 Jun 2015, 08:40 pm »
No, I didn't think anyone was interested in. Because the terminals were weak. But I fixed it and it is in near perfect condition.  So I'm going to keep it, and drive my woofers with it. In a bi-amping system.
V. ...
