Industry Circles
GR Research
Danny Richie
Stand Height for N1, N2
0 Members and 1 Guest are viewing this topic. Read 1397 times.
wshuff
5 Apr 2015, 12:25 am »
Danny,
Are the Neo3s supposed to be at ear height? I just bought a pair of SLS bookshelves that look a lot like your N1 and N2 designs. I'm trying to figure out how tall my stands need to be.
jparkhur
Re: Stand Height for N1, N2
5 Apr 2015, 12:38 am »
I like my neo tweeter at 37 inches but depends on your chair and body height. You will have to do some testing from your location if listening. Go Badgers
wshuff
Reply #2 on:
5 Apr 2015, 12:40 am »
Thanks. I won't know until the speakers are delivered, but I'm guessing 37" height would be a stand in the 22-24" range.
Go CATS!
Industry Participant
Reply #3 on:
5 Apr 2015, 07:45 pm »
The Neo 3's are very forgiving with very good off axis performance. If you're building stands, yeah, keep them at ear level, if you've alreay got stnds, you'll be fine within a fairly "lareg" range of height.
Enjoy
jay
Danny Richie
Facilitator
Reply #4 on:
6 Apr 2015, 01:51 am »
Yep, just try to get the tweeters up to an ear level while seated.
Industry Circles
GR Research
Danny Richie
