Bryston And Speaker Loads
0 Members and 1 Guest are viewing this topic. Read 1123 times.
maplegrovemusic
  • Please Be kind to your ears .... Treat your room
« on: 30 Mar 2015, 03:40 pm »
Just got off Bryston's website . Was looking at amp specs , specifically the 7 series mono blocks. No info into 2 ohms ? Does this mean they would not work with my electrostats ?
My speakers specs are : Impedance - nominal 6 ohms   minimum 1.8 ohms
Power handling - 450 watts per channel
recommended amplifier power - 150 - 200 watts
sensitivity - 83db/2.83 volts/meter
frequency response - 32hz - 24khz +- 3db
95Dyna
Re: Bryston And Speaker Loads
« Reply #1 on: 30 Mar 2015, 04:03 pm »
My 7BSST2's are driving a pair of Infinity 9 Kappas that are nominal 6 ohms but dip to .8 (not a typo) ohms at 32 hz and again at 340 hz accompanied by some nasty phase angles.  The job is a walk in the park for the 7's.  They don't break a sweat even under the most demanding material.  As for the sound, I felt like  I bought a new pair of speakers when I installed the 7's.  Your speaker's efficiency rating will be the least of your worries with these amps.
Phil A
« Reply #2 on: 30 Mar 2015, 04:59 pm »
Are you talking about the SST2s, SSTs or STs?
maplegrovemusic
« Reply #3 on: 30 Mar 2015, 08:07 pm »
All three actually . Do not know what iteration i would end up buying . If any of those would not drive the load ,info would be appreciated
Phil A
« Reply #4 on: 30 Mar 2015, 09:12 pm »
I'd have to think that the SST2 would be best.  I've owned more than one ST (still have a 3BST) and more than one SST amp.  That is not to say that the others would be a problem.
