RCA Input Shorting Plugs
0 Members and 1 Guest are viewing this topic. Read 1130 times.
hawkeye99
« on: 24 Mar 2015, 03:38 pm »
http://www.canuckaudiomart.com/details/649062168-rca_input_shorting_plugs/
Quote. "If the inputs on your particular preamp use relays to short them when not in use these plugs will offer no sonic benefit."
Question. Do Bryston preamps use these relays? Thanks.
Mike Pickett
Re: RCA Input Shorting Plugs
« Reply #1 on: 24 Mar 2015, 05:40 pm »
Some of our preamps use relays to disconnect (not short) the unused inputs, while others use a mechanical switch to do the same.  Regardless of how the input is selected, the unused input connectors are completely isolated from the circuitry in the unit, so there is no value in shorting them.
Mike
hawkeye99
« Reply #2 on: 24 Mar 2015, 06:26 pm »
Perfect. Thanks Mike.
