BR-2 Question
0 Members and 1 Guest are viewing this topic. Read 1506 times.
1ZIP
BR-2 Question
« on: 23 Mar 2015, 08:07 pm »
I have a BP17, controlling it with a BR-2.  I recently acquired a BCD-1, current on all updates. I should point out that the player came with the BCD-1 remote supplied with the early models.  The BR-2 instructions say it will control the player with out entering any codes.  But the first time I tried it nothing happened, that is until I pressed the CD button.  Now I have control of the player, but I have lost control of the BP-17, at least the power function.  Do I have to toggle back and forth somehow or......?  The instruction really need to be a little more detailed.
redbook
  • the music is the blood...........
Re: BR-2 Question
« Reply #1 on: 23 Mar 2015, 09:21 pm »
 I have to toggle between CD and Preamp.
1ZIP
Re: BR-2 Question
« Reply #2 on: 23 Mar 2015, 09:34 pm »
Any idea what the code is for the BP-17?
1ZIP
Re: BR-2 Question
« Reply #3 on: 24 Mar 2015, 05:04 am »
Finally figured this out, the BR-2 code for the BP-17 (unpublished) is the same as the code for the B100 (published).  Intuitively obvious……….NOW!   James, perhaps an undate/expansion of the
BR-2 manual is in order give the various components and functions the remote now controls.  As for myself I have enough of a problem trying to find where I last left the remote let alone trying to figure out how to program it. :)  Heaven knows what would happen if I added a DAC/BDP2. :)
R. Daneel
Re: BR-2 Question
« Reply #4 on: 26 Mar 2015, 05:31 pm »
To add to the opening post, exactly what functions of the BDP does BR-2 control?
1ZIP
Re: BR-2 Question
« Reply #5 on: 26 Mar 2015, 11:44 pm »
If you go to the last page of the attached BR-2 manual, it depicts what functions of the BDP can be controlled by the BR.
http://www.bryston.com/PDF/Manuals/300020[BR2].pdf
