Silk screened type disappearing on face of Silver BHA-1
0 Members and 1 Guest are viewing this topic. Read 6839 times.
steve in jersey
Re: Silk screened type disappearing on face of Silver BHA-1
« Reply #20 on: 10 Apr 2015, 01:59 pm »
Hmmm..... I wonder if wiping the faceplates with a soft cloth with a little carnuba wax on it occasionally would help any ? If you use it to
help protect a guitar's lacquer finish from some of the wear from hand oils it might work the same on preserving the lettering !
rob80b
« Reply #21 on: 10 Apr 2015, 02:26 pm »
Hi Steve
The issue I had with my BHA-1 is very rarely a concern with Bryston’s silk screening... even on their vintage gear… some going on 30 years…so no special treatment should be required.
Robert
steve in jersey
« Reply #22 on: 10 Apr 2015, 03:59 pm »
S'up Rob,
You know about 10min. after posting I thought that it was just a non-typical case of that particular silk screening not "taking" as well at
processing as is the norm.
I got involved in something else & forgot to delete the posting . Thanks for the reply back anyway !
rob80b
« Reply #23 on: 10 Apr 2015, 04:58 pm »
No problem Steve....as you said "just a non-typical case of that particular silk screening not "taking" but your tip is still something I'll store in the memory bank for future use.  :)
