PrimaLuna Prologue Four Tube Amp
0 Members and 1 Guest are viewing this topic. Read 2599 times.
djkzk
« on: 23 Mar 2015, 04:44 am »
Like new PrimaLuna Prologue Four tube amplifier. This has less than 50 hours of use and is in excellent shape. No scratches or dings and was only used for a short period in a smoke free, kid free and pet free home. I had planned on putting a second sound room together but that is not going to happen so I must let this go. These are excellent tube amps and are not easy to find. Any other questions or if you need additional photos, please ask. This amp is triple boxed in factory packing materials. Buyer will be responsible for shipping and paypal is great for payment. You can read my feedback on Audiogon as djkzk, Audio Asylum as iwillfish4free or ebay as djkz. Shipping is from 97702.
One of the best tube power amps you can by…regardless of price. Built with the same attention to detail as the world-renowned DiaLogue series. Adaptive AutoBias, premium parts, and point to point wiring. An incredible 35 watts per channel.
Like all ProLogue amplifiers, it boasts: •Soft-start circuit Extends component and tube life by powering up the amp gently every time you turn it on. •Tube plate fuse Protects the amplifier output stage. Other amps may need a trip to the shop if a tube fails. Not this one. Just plug in a new tube and fuse, and go. •Adaptive AutoBias. Exclusive to PrimaLuna, this circuit monitors and adjusts bias automatically. Each power tube is monitored to stay in a peak operating range. Improved performance and better sound, with distortion reduced by 40 to 50 percent over conventional designs. No need for matched tubes. No bias adjustments. Ever. It also allows you to experiment with different power tubes. Plug in virtually any power tube. Adaptive AutoBias will automatically adjust itself! In addition to EL-34s, you can use 6550, KT88, KT90, 6L6GC, KT66, 7581, EL37, and any of their equivalents. •Custom designed output transformers Encapsulated low hum, wide bandwidth for great bass and extended highs. Designed by Marcel Croese and one of the most prestigious transformer designers in the USA . •Premium parts . Fully vented chassis, chassis-mounted ceramic tube sockets, Nichicon and Realcap capacitors. WBT style speaker terminals. Gold plated input jacks. •Hand made with the finest point to point wiring, with workmanship equal to or better than any product you can buy at any price, period. •Chassis made of finely finished heavy gauge steel, and five step automotive quality finish. Each coat hand rubbed and polished. Removable tube cage included no charge. •Toroidal power transformer for low hum, and a front end that is dead quiet. •Conservative design runs tubes easy for long life.
Specifications
Output: 35 watts x 2 Freq. Response: 20Hz-85kHz +/- .5dB THD: Less than 1 percent at full power S/N Ratio: 89dB Input Sensitivity: 775mV Input Impedance: 100k Ohms Power Consumption: 210 watts Dimensions: 11" x 7.5" x 15.5" (WxHxD) Weight: 37.5 lbs Inputs: 1 pair RCA Outputs: 4 and 8 Ohm speaker taps Tube Compliment: 2 - 12AX7, 2 - 12AU7, 4 - EL34
djkzk
Re: PrimaLuna Prologue Four Tube Amp
« Reply #1 on: 23 Mar 2015, 04:48 am »
And I forgot the one thing you would probably like to know, the price.  $1450 obo, thanks.
djkzk
« Reply #2 on: 28 Mar 2015, 06:12 pm »
Just to clarify, the 3rd picture down, that is just a reflection in the amplifier, not a ding or scratch.  As I had mentioned in the opening description this thing is "like new".  Thanks
djkzk
« Reply #3 on: 21 Apr 2015, 10:05 pm »
$1350 obo
