FS: Purity Audio Design Harmony Tube Buffer SOLD
0 Members and 2 Guests are viewing this topic. Read 1133 times.
arthurs
« on: 22 Mar 2015, 02:22 am »
SOLD
This is the original version of this top notch tube buffer that not only helps with impedance matching but adds just the right amount of tube warmth and beauty to any setup.
The Harmony is a transformer coupled fully balanced 6922 based line buffer with only 1db of gain. its main purpose is to be inserted between a high quality source/DAC and preamp or power amplifier. It is absolutely ideal for use to add a touch of tonal color when using solid state components to create ideal impedance output to drive the amplifier. In my case it was inserted between my EMM Labs DAC-2X and my Dartzeel Integrated amp and was just the ticket sonically.
The Harmony is a no-compromise product that is worthy of any level of system quality. If you run a DAC directly into you amps and want a transparent stepped volume control with a touch of tubes this is the unit to get. Unit is DEAD QUIET because it essentially has no gain. Has 1 set of XLR and 1 set of RCA inputs and outputs. This unit in great condition with only normal aging and swirls in acrylic that are very hard to catch on camera.  Comes with very low hours stock tubes as I swapped out for NOS 7308's.  I'm open to selling the NOS tubes if buyer is interested.
$1100 and buyer picks up paypal and shipping from 76179
« Last Edit: 16 Nov 2015, 01:05 am by arthurs »
