SOLD!!! Audio Research LS9 Solid State Line Stage Pre-amp
0 Members and 1 Guest are viewing this topic. Read 1177 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
Audio Research LS9
$ - SOLD!
Direct from Audio Research's archives:
The LS9 is an all-new, all-solid-state line level preamplifier which replaces the LS3/3B series. Using a low-voltage, pure Class A gain circuit with direct-coupled output (no coupling caps are used in the signal path), the LS9 yields 12dB of overall gain (factory adjustable to 18dB gain if necessary).
Output capability is a substantial 24V RMS from the balanced main outputs. The LS9 also features complete IR remote control of all front panel functions, including a 70-step electronic relay volume attenuator and input selection. The LS9 offers two pairs of dedicated balanced inputs, three pairs of dedicated single-ended inputs; and a full tape monitor loop (single-ended in and out) is also provided.
The LS9 is designed to be left on continuously, drawing only 20 watts maximum continuous power. Housed in full-width 3.5" high chassis, the LS9 is a model of slim elegance that will fit neatly into almost any conceivable cabinet or shelving system. Since it generates very little heat internally, it may safely be left behind closed doors when not in use.
Frequency response   0.2Hz - 30kHz, ±0.5dB, -3dB below 0.1Hz and above 60kHz
Distortion (THD)   <0.005% at 2V RMS, balanced output
Noise & hum   20µV RMS residual IHF weighted noise output, balanced with volume control set one step up from minimum
Gain   12dB (main balanced outputs); 6dB single-ended outputs (optional 18dB available); 0dB (tape out)
Input impedance   100kOhms (balanced); 50kOhms (single-ended)
Output impedance   500 ohms (balanced); 250 ohms (single-ended); 10kOhms minimum load, 1000pF capacitance
Maximum inputs   14V RMS maximum, balanced; 7V RMS maximum, SE
Rated outputs   2V RMS into 100kOhms (balanced); 1V RMS into 50kOhms (single-ended). Maximum output capacity: 24V RMS at <1% THD at 1kHz
Dimensions   19" W x 3.5" H x 11" D
Weight   11 lbs.
« Last Edit: 22 Mar 2015, 05:42 pm by Bostown »
Bostown
Re: FS: Audio Research LS9 Solid State Line Stage Pre-amp
« Reply #1 on: 22 Mar 2015, 02:49 am »
Deal pending.. I'll update the listing according with the final outcome.
