0 Members and 1 Guest are viewing this topic. Read 2874 times.
I unscrewed both the large woofer and PR, and neither wants to come out. They're really wedged in there. I even popped that wooden plug off trying to get the woofer out. It looks like the woofer cone and the countersunk hole are extremely tight, which is whats keeping it in. I'm up for suggestion on ways to get it out. The sound actually appears to be coming from the voice coil rubbing on something on the inside of the larger woofer. Hopefully with the woofer out it'll become obvious whats wrong. It could be as simple as some stuffing getting caught in the gap. -Ian
I bought a used VMPS Larger subwoofer with a megawoofer and carbon passive radiator, and its in very good shape, but it has a problem with the active megawoofer scraping and vibrating against the pole piece. I think this might have happened during shipping, but I'm not sure. If I push back and forth on the passive radiator, the scaping sound is quite clear. Also, is there a megawoofer option for the smaller of the two active woofers? If so, is it worth upgrading that one if I have to send the larger megawoofer back?
Since I'm in Pasadena, I think you're my local dealer I'll try to let it fall out on its own then and give you an update when it does.
