Protecting a circuit board against moisture
0 Members and 1 Guest are viewing this topic. Read 2183 times.
Atlplasma
  • Just off the boat
« on: 20 Mar 2015, 08:09 pm »
This is not an audio question, but I'm hoping someone can chime in on my idea for solving an aggravating problem.
I have an energy recovery ventilator (ERV) install in my master bath. (This was a suggestion from the HVAC designer that turned out to be ill advised.) If the ERV's circuit board gets too wet (not likely at all to happen in a bathroom), it shorts and blows the onboard fuse (which is soldered to the board)  :scratch:
Can I spray the circuit board with acrylic sealer to make it susceptible to shorting? Thoughts and suggestions?
srb
Re: Protecting a circuit board against moisture
« Reply #1 on: 20 Mar 2015, 09:07 pm »
I assume you mean LESS susceptible to shorting!  ;)
I don't know about an acrylic sealer, however there are some moisture displacement sprays specifically designed for electronics, but they are not permanent.
NanoProtech Home and Garden Electric states "Long Life Protection: 1 year or more"
« Reply #2 on: 20 Mar 2015, 09:11 pm »
I would spray varnish, about 10 years protection if the circuit runn cool.
Atlplasma
  • Just off the boat
« Reply #3 on: 20 Mar 2015, 09:13 pm »
The board doesn't develop any heat. Are you talking about the type of spray varnish used for woodworking?
Atlplasma
  • Just off the boat
« Reply #4 on: 20 Mar 2015, 09:17 pm »
The Nanoprotech looks similar to this rubberized spray: http://www.boatstore.com/electro-seal-spray-11oz-ducky-products-d-1005.html?utm_source=googlepepla&utm_medium=adwords&id=74571471266&gclid=CNqD2Ibst8QCFU8vgQoddJ4A4Q.
I think I'll give the Nanoprotech a try. The board is in an enclosure and not subject to weather extremes or bulk moisture. Hopefully it would run for a few years without a problem.
My plan is to use the most promising/practical product and then conduct a test. EVR running while a hot shower fills the bathroom with steam. If it shorts out, I can replace the fuse and look for another option. FWIW. I considered moving this unit out of the bathroom, but it would be a major demolition project to make that happen.
« Reply #5 on: 20 Mar 2015, 09:35 pm »
Yes this same. Need careful just not to apply too much.
Some products as CorrosionX are oiled and attract dust.
TomS
« Reply #6 on: 20 Mar 2015, 09:46 pm »
Circuit boards in marine environment often have what's called a conformal coating, normally applied during the manufacturing process. Google is your friend, many choices.
« Reply #7 on: 20 Mar 2015, 10:16 pm »
This is a hi tech process, not easy to DIY.
http://en.wikipedia.org/wiki/Conformal_coating
randytsuch
« Reply #8 on: 20 Mar 2015, 10:19 pm »
We use conformal coating at work all the time, but have special tools too.
Looks like the sell the stuff in a can.  I would clean the board as good as you could with alcohol first, and then give it a shot.
Randy
