Any kits/design suitable for Advent Baby II cabinets?
0 Members and 1 Guest are viewing this topic. Read 1298 times.
lillys_pillow
Hello.
I've got Advent Baby II cabinets and hope to use them in a quick-to-complete project.
The enclosure is sealed, interior dims 5" deep x 13 3/4" tall by 10" wide (0.4 cu ft). The woofer circle is
about 5 5/8" in diameter. The tweeter circle is 2 3/8". Will port if appropriate.
Thanks in advance
SJM
Danny Richie
Re: Any kits/design suitable for Advent Baby II cabinets?
« Reply #1 on: 20 Mar 2015, 02:03 am »
That is not a good cabinet shape. Ideally you want your cabinet width to be 1/3 to 2/3 of the depth. Old style shoe box shaped cabinets are  not ideal and typically un-braced. I wouldn't try to save or re-use them.
Sorry that it wasn't what you were hoping for.
An another note welcome to AC and thanks for joining in.
bdp24
« Reply #2 on: 20 Mar 2015, 10:26 pm »
Hello.
Thanks in advance
SJM
You can get a pair of modern, better-designed enclosures from Parts Express for cheap.
Danny Richie
« Reply #3 on: 20 Mar 2015, 10:35 pm »
Ruben has been building some cabinets for our X-LS Encore kits for next to nothing too.
