Quested 3 x LT20 Home Theatre Speakers & 3 x Quested AP-1550 Amplifiers
0 Members and 1 Guest are viewing this topic. Read 1635 times.
Dragon_vibe
Hi All.
I was going to keep these for my apartment, as i love the sound of these speakers but unfortunately i was advised by Quested these speakers will not work in my new smaller room which is less then half the size of my theatre room. Thus, they are now up for sale. My room is much smaller then my theatre room which is now dismantled.
If you are after the very best in home theatre speakers these are the ones to get!!! don't take my word for it do your research.
Part of this package are Amplifier AP1550 with Filter Cards Installed, Each Amplifier is configured in a Bi amped Mode. One amplifier Per Speaker in Mono block configuration.
I can Split the package if you don't require the amplifier but highly recommend them as this was designed and configured for the LT20 specifically to perform with very low distortion.
What does the package Include:
3 x LT20 Speakers (With Original Box)
3 x AP1550 Amplifiers (Each Channel is Fitted with a Filter Card, One Channel for High& mid, the other for Bass)
Original Quested Shipping Packaging.
The tweeter can be changed to have a shorter throw distance. The ones installed are designed for Long Throw. Min of 4 meters away from listening position is required.
Filter cards can be removed and you can run Electronic Crossover if you want too. However the Filter cards were installed due to there natural sound higher fidelity.
Delivery Says Free within my asking price. I will ship these by Air using FedEx.
I can ship world wide by Fedex Air to most part of the world.
Spec for LT20 Speakers Below
LT20-SP Semi-passive. High End Home Theatre Speaker, Can be installed anywhere high fidelity is required over normal PA Speakers
Built-in 2-way crossover between Low and Mid/High
High-power twin 10" speakers, 6.5" Mid, with Air Motion Transformer tweeter.
Freq Resp 40Hz - 18kHz +/-2dB. Dispersion 45 x 100 (rotatable HF baffle).
Continuous Max SPL: 112db@10m, 118dB@5m, 132dB@1m
Size 580(w) x 685(h) x 440(d) mm. Weight 52kg.
Amplifier Specification:
2 Channel Class A/B Amplifier 774 Watts Per Channel In 8ohms, 1550 Watts Per Channel In 4ohms
Asking Price Includes Air shipment to most part of the USA by FedEx. Approx. 5 days shipping time.
These can also be shipped by sea if you want to save a little more.
Air Shipment takes approx. 5 Days.
Sea shipment is: 3-5 Weeks.
For the complete Set: Speakers and Amplifiers.
Asking price is: $21,200 Shipped by Fedex Air World Wide. Approx. 5 Days, For 3 Speakers and 3 Amplifiers. Total weight is well over 200 KG
Sea shipment is $20,000.00 By Sea, (Door to Port) 3-5 Weeks for delivery.
For 3 x LT Quested Speakers Only No Delivery Included: $12,600.00 US Dollars
For 3 AP-1550 Amplifiers Only with no delivery calculated: $6500.00 US Dollars.
Payment Terms:
Bank Wire is Preferred.
Paypal is also accepted If you decide For Air shipment only. Paypal Fee has to be covered by the buyer at 4.5% of total transaction value.
« Last Edit: 20 Mar 2015, 12:17 pm by Dragon_vibe »
