need help with iPeng
0 Members and 1 Guest are viewing this topic. Read 1198 times.
Nick B
« on: 17 Mar 2015, 11:05 pm »
My iPeng app used to work great controlling my SB 2, but I was fiddling with some settings recently and now iPeng only controls and plays my iPad, rather than the SB 2   :duh: I looked for the default settings, but couldn't find them. Pls help so I can play some tunes over my system again
Nick
avta
Re: need help with iPeng
« Reply #1 on: 17 Mar 2015, 11:13 pm »
contact the developer Jorge through the app. I have found him to be very helpful in the past. I no longer have an SB and it's been quite a while since I used ipeng.
Nick B
« Reply #2 on: 18 Mar 2015, 01:31 am »
OK ..that's what I'll do    thanks
mcgsxr
« Reply #3 on: 18 Mar 2015, 01:14 pm »
Likely an issue with "grouping" or not your musical sources.
You may need to delete and reinstall the app.  Should then walk you through the process of getting it all running again.
Else, you need to look at the bottom of the screen, and see what music source it is pointed at.  You can touch that to get it to open a list of available sources.
I use it to control both my main player, and my iTouch (where I bought the in app FLAC streaming so I can listen to my entire collection on my portable device when in my wifi environment) that I listen to with headphones.
Nick B
« Reply #4 on: 18 Mar 2015, 05:21 pm »
I got it working by rebooting the SB 2 and the iPad. I think the problem was that it was not "pointed" at the right device. Seems to me after the reboot I saw the icon of the SB 2 device which I don't remember seeing previously. As to the developer Joerg, he responded very quickly. What great customer service.
This program was on my wife's very old iPad and it runs 1.4.17    I'll be downloading the latest version  soon on my iPad
