Bryston 0.5B Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 1583 times.
russ_l
« on: 15 Mar 2015, 08:04 pm »
I've recently inherited a 0.5B phono preamp in / on which there is no indication of MM or MC. Would anyone know which is correct. Thanks in advance for any info.
Russ
rawbcca
Re: Bryston 0.5B Phono Preamp
« Reply #1 on: 15 Mar 2015, 08:42 pm »
The .5B phono preamp is MM there should be a row of dip switchs inside for different cartridge loads.
The .5B is identical to the BP1 phono preamp. Check Bryston's Web site for info on the BP1.
russ_l
« Reply #2 on: 16 Mar 2015, 12:18 am »
Thanks rawbcca. I'll look into the BP1.
Russ
