FS: Modwright Oppo BDP-83 Solid State Mods, Available at AXPONA
0 Members and 1 Guest are viewing this topic. Read 3789 times.
roscoeiii
Hi folks,
Thought I'd hold onto this for a long time, but a move to DEQX means that I am using digital outputs of all my gear. So time for this excellent player to go to a good home. It is in great shape, with the exception of a small scratch on the top as shown in the pic. Apologies for my awful photography skills.
Price for ACers: $550 shipped.
« Last Edit: 21 Apr 2015, 10:11 pm by roscoeiii »
roscoeiii
Re: FS: Modwright Oppo BDP-83 Solid State Mods
« Reply #1 on: 11 Mar 2015, 10:07 pm »
Some more details on the Modwritght BDP-83 SS mods and comments from other ACers who bought the unit:
Upgrade cost, not including stock Oppo, was $1000.
 Modwright replaced the analog state with a solid state one with no op amps etc., upgraded the power supply (almost always a good idea in most gear!) and  the clock was replaced.
From Modwright: "The SS output stage is VERY fast and detailed with phenomenal bass.  It also has a sweet midrange and is startlingly accurate.  It is not a tube mod, but it is a SS circuit that offers many of the strengths of tubes, in some of the same ways as our KWA 150 SS amplifier." "I would have to say that it is ON PAR with our tube-modified units.  There is a slightly different sonic character as it is SS and not tube, but it is a circuit that is more tube-like than SS in its presentation and the bass response is better defined!"
From a buyer of the Modwright with the SS mods: "As it has been a few months since I had my stock player and I don't have a stock player to directly compare to, my comparisons are mostly based on memory.  However, I can say up front that the modified player does not even closely resemble the sound of the stock player - it is so much better across the board!  There is a much better balance to the sound (before it sounded a little thin/bright) - accuracy and bass in particular stand out along with much better instrument and vocal clarity.  The improvement is apparent across all formats -the dedicated stereo outputs are phenomenal sounding for both CD and SACD and are significantly better than the Sony SCD-2000ES that Dan modified for me several years ago.  Uncompressed Blu-Ray audio out of the multichannel outputs is a revelation now - before I could not tell much if any difference between it and the compressed DD/DTS digital output via coax and having it processed by my pre/pro (a McIntosh MX119).  That is not the case at all now - the difference between compressed and uncompressed DD/DTS is as big as it should be."
From Phil A: "I spent more than a couple of hours listening.  I decided to try an A/B [of Modwright SS BDP-83] vs. the Marantz DV9600.  In my opinion not even close.  I got up 4 times to double check I was playing the SACD layer on the Marantz and realized the last time I got up check it was a single layer SACD!"
Hope this helps.
mnilan
« Reply #2 on: 12 Mar 2015, 02:26 pm »
Roscoeiii:
Thanks for the descriptions of the modifications!
Mike
roscoeiii
« Reply #3 on: 8 Apr 2015, 05:08 pm »
Time for a bump on this ad. Great sounding piece of gear!
roscoeiii
Bump time. Going to be at AXPONA? You can pick it up from me there!!!   :thumb: :thumb: :thumb:
Price will be adjusted accordingly and discounted to reflect my glee at not having to deal with shipping!
How old/how much use has it seen?
Can it be used as a DAC with optical and more importantly USB inputs?
I'm in the market to update my DAC and will be at Axpona on Saturday.
roscoeiii
No, it does not have digital inputs. Only the 103 has that functionality,  IIRC. This is just a discussion player, which will play nearly any disc, including SACD.
csmgolf
I will be at Axpona and am interested in this piece. Where will I be able to find you there? What payment method would you need? Let me know, Cris.
roscoeiii
Check your Messages.
roscoeiii
roscoeiii
