Any way to stream to a Logitech Transporter from an Ipad or smart phone?
0 Members and 1 Guest are viewing this topic. Read 1151 times.
Jazzman53
  • Jazzman's DIY Electrostatic Loudspeaker Page
    • Jazzman's Electrostatic Loudspeaker Page
Hi all,
My setup steams Itunes wirelessly to a Logitech Transporter using an Ipad App.  I have an audio frequency tone generator app on my Ipad which I would like to use for speaker tuning.  The problem is that I can’t import the tone generator into Itunes and I can’t figure out a way to steam its output from the Ipad to the Logitech directly.
Does anyone know how to do this?
Bob in St. Louis
This should work....Orange Squeeze.
Bob in St. Louis
Whoops....Here's the free version.
Your title says "iPad or Smartphone", and this is for Android only.
Hope that helps.
Vincent Kars
  • The Well Tempered Computer
Import test files into iTunes and play them on the Squeeze?
http://www.audiocheck.net/testtones_sinesweep20-20k.php
rajacat
  • Washington State
