Need help finding transistor
0 Members and 1 Guest are viewing this topic. Read 848 times.
S Clark
« on: 10 Mar 2015, 02:53 am »
I've got an amp with a transistor marked F BH 52  MPS  A06
I can find plenty MPS A06, but not with the other markings.  What do these signify?  Suggestions?
Scott
Pete Schumacher
  • It's all in the pursuit
    • Vapor Audio
Re: Need help finding transistor
« Reply #1 on: 10 Mar 2015, 03:41 am »
Scott
I'd say if the MPS A06 look like what you have then that's probably the right part.  The other letters probably are unique to the particular manufacturer of that part.
G Georgopoulos
« Reply #2 on: 10 Mar 2015, 04:57 am »
if you got a datasheet for the MPS A06 then you can find an equivalent for that,the ratings to watch out for are max voltage collector emitter,max collector current,power dissipation,beta.beta varies even in same type devices and is hardly biased in absolute beta in most designs,so yes try another with close beta...
my mistake
i misstook you couldnt find an mps a06
please use original
sorry  :oops:
