SOLD, Balanced Power Technologies BP-1, 7.5 Amp Power Isolator Conditioner
0 Members and 1 Guest are viewing this topic. Read 1841 times.
Kwebb
SOLD, Balanced Power Technologies, Model BP-1, with 7.5 ampere, continuous power rating.  I am the original owner of this balanced power conditioner isolator; it is in pristine condition, with the original B-P-T power cord, all of the original paper work, and shipping box.  This power conditioner substantially lowers the noise floor in any audiophile system.
The Model BP-1 has one, 7.5-amp (continuous rating), low noise transformer and includes 10 Hubbell premium outlets (one GFCI outlet) along with all of the following features:
• Custom low-noise, low temperature-rise, tight load regulation, high-isolation type toroidal transformer
• Perfectly balanced for maximum Common Mode Rejection
• EMI/RFI filtration to ensure ultra-low background noise
• Copper foil shields between primary & secondary windings to reduce capacitive coupling
• On/Off Carling magnetic circuit breaker switch to protect from current overload
• Wired internally with custom 12 AWG 99.99% pure Litz wire
• Multiple layers of grain oriented steel laminated around transformer circumference to attenuate magnetic fields
• Hubbell 5362 premium, top-of-the-line duplex outlet, 20-amp rated all brass outlets
• 3-layer chassis dampening
• Heavily damped black powder-coat 1/8"aluminum chassis to reduce unwanted mechanical vibrations that blur imaging and clarity
• Surge/spike protection, current overload protection and GFCI [ground-fault circuit interruption] protection
• Separate EMI/RFI noise filters on each duplex outlet to reduce component interaction
• Polypropylene X-rated audiophile-grade filter capacitors for exceptional clarity
• Model BP-1 employs ultralow-noise technology transformers
• Grounding post for equipment that benefits from a direct ground such as turntable
Buyer to pay for shipping.  Seller to pay the pay pal fees.
Local pick up is always best for both buy & seller.  Local pickup in San Diego or Orange County California.
« Last Edit: 12 Mar 2015, 10:09 pm by Kwebb »
jeffreybehr
Is this a balanced-power p-con or merely an isolation-transformer-based p-con?
Kwebb
Jeffrey,
This is a true balance Power conditioner.
Kyle
rikhav
This is one of the few true balanced isolation transformers available with all safety net
Go for it
Kwebb
Rikhav,
Yes, it is!!
Kyle
