0 Members and 2 Guests are viewing this topic. Read 29024 times.
I don't see why not, people are having a lot of luck with those eminence 15"s Alpha's in simple flat OB speaker set ups.Go 24" x 24" baffle on the lower woofer, it should sound good.
Could the Behringer CX3400 be used to play with the crossover? Is this a good option for active crossover experimentation?
So...I was studying over my friend's OB speakers which are incredible. They have 2 Eminence 15" on each side and one of them has a compression driver screwed into it. They are passively crossed at 800. How do you guys think it would work to use to Alpha 15s on the bottom of each and these Eminence 12" with a screw in compression driver on top?http://www.parts-express.com/eminence-beta-12cx-12-coaxial-driver--290-504Eminence does not make the 15" coax anymore as far as I can tell...Would it be possible to use the basic $100 minidsp with this setup ? Or would it be better to experiment with passive crossovers?Or would it not work at all?Thx
I am just building an OB with a H-frame with one Alpha 15 on the bottom. OB Driver is the 12LTA. I cut out the dust cap an fixed a cheap but very good car tweeter with neodymium magnets instead of the dustcup. Works incredibly well.Car tweeter is a Lanzar: http://cartweetersx.blogspot.de/2012/08/lanzar-dct-1-inch-silk-dome-neodymium.html
The miniDSP 4x10HD has an incredibly well designed user interface. Just load it to your computer, connect a USB cable, and you are able to make adjustments in real time. The ability to do up to a 4 way speaker, act as a preamp with volume control and a hirez DAC all in one are a huge plus, IMO.
My problem is that I just don't have that much cash. I am trying to see if I have a friend nearby who has a DSP that I can borrow for to figure out the crossover. I would prefer to ultimately have these speakers as passive instead of active.
How do you guys think it would work to use to Alpha 15s on the bottom of each and these Eminence 12" with a screw in compression driver on top?http://www.parts-express.com/eminence-beta-12cx-12-coaxial-driver--290-504Thx
