0 Members and 2 Guests are viewing this topic. Read 29022 times.
I maintain that you don't need to go multi-way or spend a ton of money to play around with this and potentially even be happy.You can, and if you want to you should.Linkwitz has done a ton of research, and shared that too, no doubt.Others here have spent tons of time finding out how this works, and why, and thankfully also share their experiences.Sure there is science to it, but I don't personally think that you have to dive in headfirst to a driver bakeoff with measurements, and multiway amplification to "hear it".If the complex solution is satisfying for you, awesome. if now, don't be put off. If this is a hobby for you, it is fine to start simple and play around.I ended up with a full ranger on a wide winged baffle, augmented with biamped OB bass. It was excellent. It was 100% shared ideas in the "Gravity well of a darkstar" thread that formed my opinions about what is possible and pleasing on a budget.I respect that there are tons of ways to find satisfaction in audio, and OB is DIY paradise.
this is just false. no fullrange driver has any dipole dispersion pattern anywhere near treble frequencies, its forword directional, with very poor offaxis control, and a dipole absolutelty needs that.doesnt come close to CD/waveguide, thats physics, OB or not.
I guess that I will have to break down and get a minidsp as well. I have tried to avoid going this direction but it might be inevitable. Everyone who does an active design really raves about it.
My latest OB pairs an Eminence Alpha 15A and a Fostex FF85WK full range driver. The baffle is 18" wide by 24" tall and is tilted back 15 degrees. Second order crossover, active or passive (I like the passive version much better), works well. Good bass from the 15A, the Fostex full range driver is very smooth all the way to 20 kHz, and best of all low cost. Great performance at an entry level price.
The details of the design can be found here :http://www.quarter-wave.com/Project12/Project12.htmlThe page is under construction so I will be adding more details and a full write up in the future. The baffle size, drivers used, and crossover design all go together. If you change one you need to rejuggle the other two. This is a new combination of drivers for me and a redesigned passive crossover. I have built a few other OB speakers all of them significantly bigger, they get smaller with each design iteration, and this "compact" OB has really good bass and feedback on the performance has been very positive.
Thanks! Nice work sheet. I have a baffle in this width. Did a OB project that didn't work well. It has the Alpha 15 cut out. Are the values on page 5 for the crossover close enough for use now? Or should we wait for more feedback?
Thanks again. Looks like the in room SPL is around 82 to 83 average?
Good to see you writing about OB on this site again! Just curious how you calculated the offset on the FF85WK drivers. From the first photo it appears slightly offset?
