0 Members and 1 Guest are viewing this topic. Read 72848 times.
That is odd.
could the tonearm on this table (the Pioneer) be swapped out easily or would it involve major surgery?
Lymbo90,Welcome to vinyl circle. Glad you decided to post.With a fully manual table the biggest problem would be devising a mounting surface (armboard) and physically securing the new arm at the right distance and height. This would probably eliminate 12" arms unless you took extreme measures. I don't know about the PLX-1000 arm bearings, but Pioneer took a different approach to arm damping/microphonics - it's internal:I read somewhere (here?) there is some play in the bearings. This might be an isolated instance, but it should be an easy fix. There will be a service manual. I don't know if it's widely available yet. A better arm could cost more than the table. If there's a problem with a new table, send it back.neo
There is an issue with some of the tables having loose tonearm bearings. A friend of mine got one but his replacement was fine.I discovered the buzz Wayner was talking about. I tried the supplied headshell and wow...buzzzzzz. Immediately swapped it out with my Ortofon headshell and dead quiet. So I definitely don't think it was the Grado. The Pioneer headshell blows!
Do you mind to post the model # for that Ortofon headshell?
I only want to add that I bought a PLX-1000 and set it up last Friday. Listened to it all weekend. I did some homework before the purchase and was aware that a headshell with longer slots was needed to obtain a baerwald alighnment, so I ordered a couple of headshells when I bought the table. I also purchased a Way Excellent II mat from Herbie's Audio Lab and some Sorbothane boots from KAB. The cartridge I am using is a Nagaoka MP-200. After about 25 hours of listening to a lot of rock, jazz, and classical LPs I think the table is a keeper. Very solid build quality and excellent performance in my opinion. I had no problems with alignment and the VTA adjustment. The antiskate works fine on my table. And I get absolutely no hum (all of my audio gear is run through a power conditioner). I agree, however, with the earlier comment about the tonearm queuing lever -- it is not sufficiently damped to give the stylus a gentle ride down into the lead-in groove so I handle that chore manually.As a point of reference I have at one time or another had the following setups over the last 10 years.Garrard 401 in custom walnut plinth with two Jelco arms and Ortofon SPU stereo and mono MC cartsSOTA Star Sapphire Vacuum Platter turntable with an SME 309 tonearm and Ortofon Jubilee MC cart (boron cantilever and nude shibata stylus)Rega P7 with Benz Glider MC cartridgeI can't say that any of the above tables were better for spinning records than the Pioneer PLX-1000. Feel free to take that with a large grain of salt if you like. But I am very pleased so far with the Pioneer and will be buying a second unit with a mono cartridge that will be used only for mono LPs cut in the 1950s and 60s (I have a large collection of them).For those sitting on the fence my suggestion is that you Google for as many documented owner experiences as you can find. You are doing yourself a disservice if you are making buying decisions based on one person's review and perspective -- everyone has some degree of bias whether they care to admit it or not. Some of us PLX-1000 owners knew what we were buying going in and didn't mind spending a few extra dollars to get the most out of the turntable. And people should accept that no product is without its detractors and that in manufacturing some very small percentage of products will be defective.What the PLX-1000 seriously lacks is audio snob appeal (not really a problem for me but it will be a deal breaker for some). It is not massively over-engineered and will not attract people with more upscale tastes who care as much if not more about aesthetics as they do performance. But purely as a platform for spinning records I would not hesitate to recommend the PLX-1000 to someone who wants excellent vinyl playback performance but doesn't want to spend a small fortune to get it. --Jerome
