Industry Circles
Bryston Limited
BDP never finishes updating
0 Members and 1 Guest are viewing this topic. Read 722 times.
Marius
28 Feb 2015, 12:18 pm »
HI Chris,
My BDP1 with latest beta MM won't finish a selective update, nor the full DB update. This is new to my setup, until your latest version all went fine. With yesterdays version (the one with the Home functionality) my newly dl'd Tintinabuli from the Tallis Scholars is seen (shows up in red) but never added to the DB. Been trying for 2 hours now, even rebooted couple of times. Front panel shows the individual tracks, but isn't able to play them either. MPOD won't list the files at all.
Files are ok, i can play them with Audirvana+ without issue. 24 bit 192k
http://www.gimell.com/recording-arvo-part---tintinnabuli.aspx
What to do?
Marius
Marius
Re: BDP never finishes updating
28 Feb 2015, 04:36 pm »
well, it finally finished after all, i think it took about 5 hours though for 1 24/192 album.
Marius
Industry Circles
Bryston Limited
